A Requirements Evaluation Method for Ships to Maximize Operational Value under Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kazuo Hiekata
  • Fonction : Auteur
  • PersonId : 991272
Bryan Moser
  • Fonction : Auteur
  • PersonId : 991273
Requirements defined by shipping firms play a role as the communication interface of product information between these firms and shipbuilders, and the product design is optimized based on the requirements. Ship service life is about 30 years, during which original requirements may lose some relevance. In this paper we explore the introduction of uncertainty and flexibility into requirements so that ships are designed optimally not only for a single given technical condition but for a range of possible operational scenarios, including shifts in the economic environment for shipping firms.
978-3-662-45937-9_16_Chapter.pdf (658.26 Ko) Télécharger le fichier
hal-01386491 , version 1 (24-10-2016)
Paternité
Kazuo Hiekata, Bryan Moser. A Requirements Evaluation Method for Ships to Maximize Operational Value under Uncertainty. 11th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2014, Yokohama, Japan. pp.149-158, ⟨10.1007/978-3-662-45937-9_16⟩. ⟨hal-01386491⟩
82 Consultations
133 Téléchargements
