Unification of Multiple Models for Complex System Development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the design of automotive product, the constant evolution of customer requirements and international regulations leads to new considerations of the sys- tem design process. The authors propose a modeling approach for complex system design based on the coupling of collaborative models and heterogeneous experts’ (i.e. authoring) models used for product behavior assessment. The approach aims at modeling a system at different systemic and temporal levels in the design process and allows a flexible navigation with the possibility of changing or adding models in the design space. The purpose behind the use of this approach is to lead to an optimal design solution in the context of innovative design for complex system.
978-3-662-45937-9_27_Chapter.pdf (472.66 Ko) Télécharger le fichier
hal-01386507 , version 1 (24-10-2016)
Paternité
Nesrine Ben Beldi, Lionel Roucoules, François Malburet, Tomasz Krysinski, Pierre Gauthier. Unification of Multiple Models for Complex System Development. 11th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2014, Yokohama, Japan. pp.267-276, ⟨10.1007/978-3-662-45937-9_27⟩. ⟨hal-01386507⟩
130 Consultations
276 Téléchargements
