Product Data Management – Defining the Used Terms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Merja Huhtala
  • Fonction : Auteur
  • PersonId : 991309
Mika Lohtander
  • Fonction : Auteur
  • PersonId : 991310
Juha Varis
  • Fonction : Auteur
  • PersonId : 991311
The Product Data Management (PDM) system and its associated terminology have changed over the years. Product Lifecycle Management (PLM) has become the predominant system and tends to overshadow PDM. However, PDM remains relevant and is a system commonly used by design engineers; mainly as a storage place for drawings and a place where drawings can be found for further editing.To obtain full benefit from the PDM/PLM systems, precise definitions are required. Without such definitions, the systems cannot function as they should and they cannot be used optimally. Furthermore, shortcomings in definitions may lead to a situation where the engineering community is unaware of the kind of help the systems can offer.The main focus of this conference paper is definition of some of the terms inherent to PDM/PLM systems and their data.
978-3-662-45937-9_38_Chapter.pdf (247.11 Ko) Télécharger le fichier
hal-01386542 , version 1 (24-10-2016)
Paternité
Merja Huhtala, Mika Lohtander, Juha Varis. Product Data Management – Defining the Used Terms. 11th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2014, Yokohama, Japan. pp.387-396, ⟨10.1007/978-3-662-45937-9_38⟩. ⟨hal-01386542⟩
53 Consultations
431 Téléchargements
