Skill-Based Asset Management: A PLM-Approach for Reconfigurable Production Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kiril Aleksandrov
  • Fonction : Auteur
  • PersonId : 991318
Viktor Schubert
  • Fonction : Auteur
  • PersonId : 991319
Jivka Ovtcharova
  • Fonction : Auteur
  • PersonId : 990090
To handle complexity in a modern reconfigurable production system from a strategic and tactical planning perspective as well as to enable operational decision making a skill-based asset management system is introduced. It provides a novel approach of managing assets in the context of the asset lifecycle based on their provided skills. It aims at the vertical integration of higher level management systems with production execution level systems of small and medium sized manufacturing enterprises, using a common skill-based abstraction. Thus the skill-based asset management system can effectively provide digital factory functionality to companies while integrating into their existing IT systems.
978-3-662-45937-9_46_Chapter.pdf (805.69 Ko) Télécharger le fichier
hal-01386554 , version 1 (24-10-2016)
Paternité
Kiril Aleksandrov, Viktor Schubert, Jivka Ovtcharova. Skill-Based Asset Management: A PLM-Approach for Reconfigurable Production Systems. 11th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2014, Yokohama, Japan. pp.465-474, ⟨10.1007/978-3-662-45937-9_46⟩. ⟨hal-01386554⟩
105 Consultations
279 Téléchargements
