Fluid-rigid structure interaction system with Coulomb's law - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2017
We propose a new model in a fluid-structure system composed by a rigid body and a viscous incompress-ible fluid using a boundary condition based on Coulomb's law. This boundary condition allows the fluid to slip on the boundary if the tangential component of the stress is too large. In the opposite case, we recover the standard Dirichlet boundary condition. The governing equations are the Navier-Stokes system for the fluid and the Newton laws for the body. The corresponding coupled system can be written as a variational inequality. We prove that there exists a weak solution of this system.
jsm-ls-tt_2016-10-10.pdf (297.26 Ko) Télécharger le fichier
hal-01386574 , version 1 (24-10-2016)
Loredana Bălilescu, Jorge San Martín, Takéo Takahashi. Fluid-rigid structure interaction system with Coulomb's law. SIAM Journal on Mathematical Analysis, 2017, 49 (6), pp.4625-4657. ⟨10.1137/16M1099947⟩. ⟨hal-01386574⟩
249 Consultations
136 Téléchargements
