Unified IoT Ontology to Enable Interoperability and Federation of Testbeds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
After a thorough analysis of existing Internet of Things (IoT) related ontologies, in this paper we propose a solution that aims to achieve semantic interoperability among heterogeneous testbeds. Our model is framed within the EU H2020's FIESTA-IoT project, that aims to seamlessly support the federation of testbeds through the usage of semantic-based technologies. Our proposed model (ontology) takes inspiration from the well-known Noy et al. methodology for reusing and interconnecting existing ontologies. To build the ontology, we leverage a number of core concepts from various mainstream ontologies and taxonomies, such as Semantic Sensor Network (SSN), M3-lite (a lite version of M3 and also an outcome of this study), WGS84, IoT-lite, Time, and DUL. In addition, we also introduce a set of tools that aims to help external testbeds adapt their respective datasets to the developed ontology.
wf-iot-2016.pdf (376.04 Ko) Télécharger le fichier
hal-01386917 , version 1 (24-10-2016)
Rachit Agarwal, David Gomez Fernandez, Tarek Elsaleh, Amelie Gyrard, Jorge Lanza, et al.. Unified IoT Ontology to Enable Interoperability and Federation of Testbeds. 3rd IEEE World Forum on Internet of Things, Dec 2016, Reston, United States. ⟨10.1109/WF-IoT.2016.7845470⟩. ⟨hal-01386917⟩
Collections
INRIA INRIA2
469 Consultations
1443 Téléchargements
