Occurrence of selected micropollutants in treated wastewater and removal with optimised tertiary treatments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Occurrence de micropolluants sélectionnés dans les eaux traitées et élimination par des procédés de traitement tertiaire
Two tertiary treatments were studied at pilot scale in three different plants. An advanced oxidation processes pilot was tested in two plants with two different upstream treatment processes: a membrane bioreactor and a low load activated sludge followed by a sand filter. An activated carbon pilot was tested in one plant, a low load activated sludge followed by a sand filter and an ozone reactor. 64 micropollutants were analysed in the samples of this study. The tertiary treatments studied, ozone, AOP and activated carbon, were efficient for the removal of most of the micropollutants analysed in this study, except metals.
ly2013-pub00050465.pdf (625.77 Ko) Télécharger le fichier
hal-01387103 , version 1 (27-10-2016)
S. Besnault, S. Martin Ruel, S. Baig, B. Heiniger, M. Esperanza, et al.. Occurrence of selected micropollutants in treated wastewater and removal with optimised tertiary treatments. 8th IWA Specialist Conference on Assessment and Control of Micropollutants/Hazardous Substances in Water (IWA Micropol Ecohazard), Jun 2013, Zurich, Switzerland. 3 p. ⟨hal-01387103⟩
123 Consultations
408 Téléchargements
