Supply Uncertainty in Food Processing Supply Chain: Sources and Coping Strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Atanu Chaudhuri
  • Fonction : Auteur
  • PersonId : 991423
Iskra Dukovska-Popovska
  • Fonction : Auteur
  • PersonId : 991424
Cecilie Maria Damgaard
  • Fonction : Auteur
  • PersonId : 991425
Hans-Henrik Hvolby
  • Fonction : Auteur
  • PersonId : 991426
Supply uncertainty aspects haven’t been treated specifically in the food processing supply chain management literature, as the focus was mainly on the demand aspects. This paper provides an initial survey on the existing literature dealing with supply uncertainty of food processors. Specifically, the focus is on the types of supply uncertainty and sources that are causing them, as well as how the food processing companies are coping with it in the food supply chain.
978-3-662-44733-8_23_Chapter.pdf (272.09 Ko) Télécharger le fichier
hal-01387179 , version 1 (25-10-2016)
Paternité
Atanu Chaudhuri, Iskra Dukovska-Popovska, Cecilie Maria Damgaard, Hans-Henrik Hvolby. Supply Uncertainty in Food Processing Supply Chain: Sources and Coping Strategies. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.183-191, ⟨10.1007/978-3-662-44733-8_23⟩. ⟨hal-01387179⟩
130 Consultations
977 Téléchargements
