Outline of a Methodic Realization of Construction Kits for Changeable Production Systems - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2014
This paper outlines a method to structure a construction kit system for assembly and manufacturing systems in a way, that a realised system from those building blocks fulfils the requirement of ease in reconfiguration considering specified change criteria (i.e. variants, capacity) at an adequate degree. An overview regarding the major engineering domains and applicable literature is given. The basic flow in this method is given and important steps described. This paper finishes with describing further steps for finalizing the method.
978-3-662-44733-8_24_Chapter.pdf (128.73 Ko) Télécharger le fichier
Dates and versions
hal-01387180 , version 1 (25-10-2016)
Attribution
Identifiers
Cite
Michael Quade, David Jentsch, Egon Mueller. Outline of a Methodic Realization of Construction Kits for Changeable Production Systems. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.192-199, ⟨10.1007/978-3-662-44733-8_24⟩. ⟨hal-01387180⟩
211 View
137 Download
Share
