Exploring Alternatives of Accounting for Environmental Liabilities in the Company’s Balance Sheet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Environmental concerns have recently reached the stock market, in which investors want analyze the company’s related-risks in causing environmental damages. Usually, the Company’s Balance Sheet (CBS) is summarized, disallowing a clear interpretation of environmental issues. Methods used to valuate environmental liabilities are often subjective, which create communication problems. The aims of this work are (i) to explore alternatives for CBS structural presentation to clearly represent environmental liabilities, which allow an efficient communication with society and investors, and (ii) to assess a methodological alternative of valuating environmental liabilities under economical terms. The “Petrobras” S.A. Brazilian Oil Company is taken as a case study by accounting its oil spill related-incidents occurred in 2000 yr. Results show that an improved CBS structure should represent the company’s environmental related-issues. Additionally, emergy accounting appears as a powerful alternative to replace/substitute contingent valuation to quantify environmental liabilities under economic terms.
978-3-662-44736-9_23_Chapter.pdf (389.31 Ko) Télécharger le fichier
hal-01387865 , version 1 (26-10-2016)
Paternité
Fernando A. Bortuluzi, Feni Agostinho, Cecília De Almeida, Silvia Bonilla, Biagio F. Gianetti. Exploring Alternatives of Accounting for Environmental Liabilities in the Company’s Balance Sheet. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.187-196, ⟨10.1007/978-3-662-44736-9_23⟩. ⟨hal-01387865⟩
129 Consultations
119 Téléchargements
