Framework for Information Sharing in a Small-to-Medium Port System Supply Chain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peter Bjerg Olesen
  • Fonction : Auteur
  • PersonId : 991798
Cecilie Maria Damgaard
  • Fonction : Auteur
  • PersonId : 991799
Hans-Henrik Hvolby
  • Fonction : Auteur
  • PersonId : 991658
Iskra Dukovska-Popovska
  • Fonction : Auteur
  • PersonId : 991784
Small-to-medium ports are characterised with inefficient, ineffective and resource intensive information sharing, which is not supporting their complex and dynamic environment. This creates challenges both for optimizing the internal planning of the activities at the port according to the demand, and for stronger supply chain integration with the external actors. This paper focuses on identifying the needs and criteria for an information sharing system, and proposes an approach for sharing operational data in port systems for improved supply chain integration, in the context of logistic engineering. The proposed approach has the potential to alleviate some of the problems when operating in a dynamic demand environment.
978-3-662-44739-0_32_Chapter.pdf (313.52 Ko) Télécharger le fichier
hal-01388256 , version 1 (26-10-2016)
Paternité
Peter Bjerg Olesen, Cecilie Maria Damgaard, Hans-Henrik Hvolby, Iskra Dukovska-Popovska, Anita Friis Sommer. Framework for Information Sharing in a Small-to-Medium Port System Supply Chain. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.257-264, ⟨10.1007/978-3-662-44739-0_32⟩. ⟨hal-01388256⟩
172 Consultations
235 Téléchargements
