Linear-size suffix tries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2016
Suffix trees are highly regarded data structures for text indexing and string algorithms [MCreight 76, Weiner 73]. For any given string w of length n=|w|, a suffix tree for w takes O(n) nodes and links. It is often presented as a compacted version of a suffix trie for w, where the latter is the trie (or digital search tree) built on the suffixes of w. Here the compaction process replaces each maximal chain of unary nodes with a single arc. For this, the suffix tree requires that the labels of its arcs are substrings encoded as pointers to w (or equivalent information). On the contrary, the arcs of the suffix trie are labeled by single symbols but there can be Θ(n²) nodes and links for suffix tries in the worst case because of their unary nodes. It is an interesting question if the suffix trie can be stored using O(n) nodes. We present the linear-size suffix trie, which guarantees O(n) nodes. We use a new technique for reducing the number of unary nodes to O(n), that stems from some results on antidictionaries. For instance, by using the linear-size suffix trie, we are able to check whether a pattern p of length m=|p| occurs in w in O(m log⁡|Σ|) time and we can find the longest common substring of two strings w1 and w2 in O((|w1|+|w2|) log⁡|Σ|) time for an alphabet Σ.
LinearSizeSuffixTrie4.pdf (187.62 Ko) Télécharger le fichier
hal-01388452 , version 1 (30-05-2017)
Maxime Crochemore, Chiara Epifanio, Roberto Grossi, Filippo Mignosi. Linear-size suffix tries. Theoretical Computer Science, 2016, 638, pp.171 - 178. ⟨10.1016/j.tcs.2016.04.002⟩. ⟨hal-01388452⟩
286 Consultations
455 Téléchargements
