An Empirical Investigation of Lead Time Distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peter Nielsen
  • Fonction : Auteur
  • PersonId : 991697
Zbigniew Michna
  • Fonction : Auteur
  • PersonId : 991855
Ngoc Dung Do
  • Fonction : Auteur
  • PersonId : 991854
This paper proposes a methodology for analyzing lead time behavior. The method focuses on identifying whether lead times are in fact identically independently distributed (i.i.d.). The method uses a combination of time series analysis, Kolmogorov-Smirnov’s test for similar distributions and data sampling to arrive at its result. The method is applied to data obtained from a manufacturing company. The conclusions are that while the lead time to customers can for some products be assumed to be i.i.d. this is not uniformly true. Some products’ lead times are in fact neither independently nor identically distributed.
978-3-662-44739-0_53_Chapter.pdf (145.78 Ko) Télécharger le fichier
hal-01388573 , version 1 (27-10-2016)
Paternité
Peter Nielsen, Zbigniew Michna, Ngoc Dung Do. An Empirical Investigation of Lead Time Distributions. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.435-442, ⟨10.1007/978-3-662-44739-0_53⟩. ⟨hal-01388573⟩
46 Consultations
172 Téléchargements
