Exploring the Integration of Maintenance with Production Management in SMEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marco Macchi
  • Fonction : Auteur
  • PersonId : 991431
Alessandro Pozzetti
  • Fonction : Auteur
  • PersonId : 991432
Luca Fumagalli
  • Fonction : Auteur
  • PersonId : 991786
The paper presents the results of an exploratory research based on 10 SMEs used as case studies with the purpose to observe the state of practices with regard to the integration of maintenance with production management. The research intends to provide an evaluation of the quality of integration by means of a maturity assessment method. The resulting evidences allow an initial concern on strengths and weaknesses of maintenance management and its relationship with production management in SMEs.
978-3-662-44739-0_62_Chapter.pdf (403.59 Ko) Télécharger le fichier
hal-01388585 , version 1 (27-10-2016)
Paternité
Marco Macchi, Alessandro Pozzetti, Luca Fumagalli. Exploring the Integration of Maintenance with Production Management in SMEs. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.507-514, ⟨10.1007/978-3-662-44739-0_62⟩. ⟨hal-01388585⟩
59 Consultations
162 Téléchargements
