A GPU-based Branch-and-Bound algorithm using Integer-Vector-Matrix data structure - Archive ouverte HAL Access content directly
Journal Articles Parallel Computing Year : 2016
Branch-and-Bound (B&B) algorithms are tree-based exploratory methods for solving combinatorial optimization problems exactly to optimality. These problems are often large in size and known to be NP-hard to solve. The construction and exploration of the B&B-tree are performed using four operators: branching, bounding, selection and pruning. Such algorithms are irregular which makes their parallel design and implementation on GPU challenging. Existing GPU-accelerated B&B algorithms perform only a part of the algorithm on the GPU and rely on the transfer of pools of subproblems across the PCI Express bus to the device. To the best of our knowledge, the algorithm presented in this paper is the first GPU-based B&B algorithm that performs all four operators on the device and subsequently avoids the data transfer bottleneck between CPU and GPU. The implementation on GPU is based on the Integer-Vector-Matrix (IVM) data structure which is used instead of a conventional linked-list to store and manage the pool of subproblems. This paper revisits the IVM-based B&B algorithm on the GPU, addressing the irregularity of the algorithm in terms of workload, memory access patterns and control flow. In particular, the focus is put on reducing thread divergence by making a judicious choice for the mapping of threads onto the data. Compared to a GPU-accelerated B&B based on a linked-list, the algorithm presented in this paper solves a set of standard flowshop instances on average 3.3 times faster.
Gmys_et_al_revised_Manuscript.pdf (1.87 Mo) Télécharger le fichier
Dates and versions
hal-01389471 , version 1 (28-10-2016)
Identifiers
Cite
Jan Gmys, Mohand Mezmaz, Nouredine Melab, Daniel Tuyttens. A GPU-based Branch-and-Bound algorithm using Integer-Vector-Matrix data structure. Parallel Computing, 2016, Parallel Computing, 59, pp.119-139. ⟨10.1016/j.parco.2016.01.008⟩. ⟨hal-01389471⟩
158 View
559 Download
Share
