Rule Extraction with Guaranteed Fidelity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ulf Johansson
  • Fonction : Auteur
  • PersonId : 992372
Rikard König
  • Fonction : Auteur
  • PersonId : 992380
Henrik Linusson
  • Fonction : Auteur
  • PersonId : 992371
Tuve Löfström
  • Fonction : Auteur
  • PersonId : 992374
Henrik Boström
  • Fonction : Auteur
  • PersonId : 992373
This paper extends the conformal prediction framework to rule extraction, making it possible to extract interpretable models from opaque models in a setting where either the infidelity or the error rate is bounded by a predefined significance level. Experimental results on 27 publicly available data sets show that all three setups evaluated produced valid and rather efficient conformal predictors. The implication is that augmenting rule extraction with conformal prediction allows extraction of models where test set errors or test sets infidelities are guaranteed to be lower than a chosen acceptable level. Clearly this is beneficial for both typical rule extraction scenarios, i.e., either when the purpose is to explain an existing opaque model, or when it is to build a predictive model that must be interpretable.
978-3-662-44722-2_30_Chapter.pdf (238 Ko) Télécharger le fichier
hal-01391055 , version 1 (02-11-2016)
Paternité
Ulf Johansson, Rikard König, Henrik Linusson, Tuve Löfström, Henrik Boström. Rule Extraction with Guaranteed Fidelity. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.281-290, ⟨10.1007/978-3-662-44722-2_30⟩. ⟨hal-01391055⟩
86 Consultations
175 Téléchargements
