A Partially-Observable Markov Decision Process for Dealing with Dynamically Changing Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Partially Observable Markov Decision Processes (POMDPs) have been met with great success in planning domains where agents must balance actions that provide knowledge and actions that provide reward. Recently, nonparametric Bayesian methods have been successfully applied to POMDPs to obviate the need of a priori knowledge of the size of the state space, allowing to assume that the number of visited states may grow as the agent explores its environment. These approaches rely on the assumption that the agent’s environment remains stationary; however, in real-world scenarios the environment may change over time. In this work, we aim to address this inadequacy by introducing a dynamic nonparametric Bayesian POMDP model that both allows for automatic inference of the (distributional) representations of POMDP states, and for capturing non-stationarity in the modeled environments. Formulation of our method is based on imposition of a suitable dynamic hierarchical Dirichlet process (dHDP) prior over state transitions. We derive efficient algorithms for model inference and action planning and evaluate it on several benchmark tasks.
978-3-662-44654-6_11_Chapter.pdf (204.15 Ko) Télécharger le fichier
hal-01391299 , version 1 (03-11-2016)
Paternité
Sotirios P. Chatzis, Dimitrios Kosmopoulos. A Partially-Observable Markov Decision Process for Dealing with Dynamically Changing Environments. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.111-120, ⟨10.1007/978-3-662-44654-6_11⟩. ⟨hal-01391299⟩
131 Consultations
264 Téléchargements
