TSK Fuzzy Modeling with Nonlinear Consequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jacek Kabziński
  • Fonction : Auteur
  • PersonId : 991079
Jarosław Kacerka
  • Fonction : Auteur
  • PersonId : 992501
We propose to generalize TSK fuzzy model applying nonlinear functions in the rule consequences. We provide the model description and parameterization and discus the problem of model training and we recommend PSO for tuning parameters in membership functions and in nonlinear part of a rule consequence. We also propose some more or less formalized approach to nonlinear consequence selection and construction. Several examples demonstrate the main features of the proposed fuzzy models. The proposed approach reduces the average obtained model Root Mean Square Error (RMSE) with regard to the linear fuzzy model, as well that it allows to reduce the model complexity preserving the desired accuracy.
978-3-662-44654-6_49_Chapter.pdf (334.9 Ko) Télécharger le fichier
hal-01391351 , version 1 (03-11-2016)
Paternité
Jacek Kabziński, Jarosław Kacerka. TSK Fuzzy Modeling with Nonlinear Consequences. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.498-507, ⟨10.1007/978-3-662-44654-6_49⟩. ⟨hal-01391351⟩
58 Consultations
295 Téléchargements
