The Sensing Enterprise: Towards the Next Generation Dynamic Virtual Organisations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In today’s dynamic and volatile global environment, established legacy concepts such as Virtual Organisations (VOs) need to be evolved to enhance their agility in order to promptly adapt to changes. This paper proposes the use of the Sensing Enterprise concept and properties, supported by the paradigms of the Internet of Things, Cyber-Physical Systems and Future Internet Enterprise Systems, as an essential enabler towards the advancement of the current ‘dynamically created’ VO concept towards a Next Generation of agile and genuinely Dynamic Virtual Organisations (DVOs), displaying awareness, perceptivity, intelligence and extroversion. The properties and benefits of the Next Generation ‘sensing’ DVO are defined and then illustrated in a scenario that typically requires utmost agility and dynamism.
978-3-662-44745-1_20_Chapter.pdf (102.54 Ko) Télécharger le fichier
hal-01392117 , version 1 (04-11-2016)
Paternité
Ovidiu Noran, David Romero, Milan Zdravkovic. The Sensing Enterprise: Towards the Next Generation Dynamic Virtual Organisations. 15th Working Conference on Virtual Enterprises (PROVE), Oct 2014, Amsterdam, Netherlands. pp.209-216, ⟨10.1007/978-3-662-44745-1_20⟩. ⟨hal-01392117⟩
81 Consultations
113 Téléchargements
