Towards a Generic Enterprise Systems Architecture Based on Cyber-Physical Systems Principles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Systems that can tightly integrate physical with virtual components have represented a priority for the research in the area of ICT. Research efforts have been concentrated in domains such as: Internet of Things, Internet of Services and recently in the domain of Cyber Physical Systems. An important driver for the area of research is represented by the large-scale integration of the physical and cyber worlds. The authors propose a Generic Information System Architecture for Cyber Intelligent Enterprise by taking into account the paradigms of Cyber-Physical Systems.
978-3-662-44745-1_24_Chapter.pdf (238.96 Ko) Télécharger le fichier
hal-01392122 , version 1 (04-11-2016)
Paternité
Aurelian Mihai Stanescu, Dragos Repta, Mihnea Alexandru Moisescu, Ioan Stefan Sacala, Monika Benea. Towards a Generic Enterprise Systems Architecture Based on Cyber-Physical Systems Principles. 15th Working Conference on Virtual Enterprises (PROVE), Oct 2014, Amsterdam, Netherlands. pp.245-252, ⟨10.1007/978-3-662-44745-1_24⟩. ⟨hal-01392122⟩
122 Consultations
195 Téléchargements
