Co-scheduling algorithms for cache-partitioned systems
Cache-partitioned architectures allow subsections of the
shared last-level cache (LLC) to be exclusively reserved for some
applications. This technique dramatically limits interactions between applications
that are concurrently executing on a multi-core machine.
Consider n applications that execute concurrently, with the objective to minimize the makespan,
defined as the maximum completion time of the n applications.
Key scheduling questions are: (i)
which proportion
of cache and (ii) how many processors should be given to each application?
Here, we assign rational numbers of processors to each application,
since they can be shared across applications through multi-threading.
In this paper, we provide answers to (i) and (ii) for perfectly parallel applications.
Even though
the problem is shown to be NP-complete, we give key elements to determine
the subset of applications that should share the LLC
(while remaining ones only use their smaller private cache). Building upon these results,
we design efficient heuristics for general applications.
Extensive simulations demonstrate the usefulness of co-scheduling
when our efficient cache partitioning strategies are deployed.
