Stochastic representation of the Reynolds transport theorem: revisiting large-scale modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Fluids Année : 2017
We explore the potential of a formulation of the Navier-Stokes equations incorporating a random description of the small-scale velocity component. This model, established from a version of the Reynolds transport theorem adapted to a stochastic representation of the flow, gives rise to a large-scale description of the flow dynamics in which emerges an anisotropic subgrid tensor, reminiscent to the Reynolds stress tensor, together with a drift correction due to an inhomogeneous turbulence. The corresponding subgrid model, which depends on the small scales velocity variance, generalizes the Boussinesq eddy viscosity assumption. However, it is not anymore obtained from an analogy with molecular dissipation but ensues rigorously from the random modeling of the flow. This principle allows us to propose several subgrid models defined directly on the resolved flow component. We assess and compare numerically those models on a standard Green-Taylor vortex flow at Reynolds numbers Re=1600, Re=3000 and Re=5000. The numerical simulations, carried out with an accurate divergence-free scheme, outperform classical large-eddies formulations and provides a simple demonstration of the pertinence of the proposed large-scale modeling.
EM-CF-V2.pdf (2.38 Mo) Télécharger le fichier
hal-01394780 , version 1 (09-11-2016)
hal-01394780 , version 2 (15-08-2017)
Souleymane Kadri Harouna, Etienne Mémin. Stochastic representation of the Reynolds transport theorem: revisiting large-scale modeling. Computers and Fluids, 2017, 156, pp.456-469. ⟨10.1016/j.compfluid.2017.08.017⟩. ⟨hal-01394780v2⟩
938 Consultations
323 Téléchargements
