Symbolic Models for Isolated Execution Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Isolated Execution Environments (IEEs), such as ARM TrustZone and Intel SGX, offer the possibility to execute sensitive code in isolation from other malicious programs, running on the same machine, or a potentially corrupted OS. A key feature of IEEs is the ability to produce reports binding cryptographically a message to the program that produced it, typically ensuring that this message is the result of the given program running on an IEE. We present a symbolic model for specifying and verifying applications that make use of such features. For this we introduce the S$\ell$APIC process calculus, that allows to reason about reports issued at given locations. We also provide tool support, extending the SAPIC/TAMARIN toolchain and demonstrate the applicability of our framework on several examples implementing secure outsourced computation (SOC), a secure licensing protocol and a one-time password protocol that all rely on such IEEs.
main.pdf (415.08 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01396291 , version 1 (02-02-2017)
Charlie Jacomme, Steve Kremer, Guillaume Scerri. Symbolic Models for Isolated Execution Environments. 2nd IEEE European Symposium on Security and Privacy (EuroS&P'17), Apr 2017, Paris, France. ⟨10.1109/EuroSP.2017.16⟩. ⟨hal-01396291⟩
620 Consultations
271 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
