A Unifying Model for Camera Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2017
This paper proposes a unified theory for calibrating a wide variety of camera models such as pinhole, fisheye, cata-dioptric, and multi-camera networks. We model any camera as a set of image pixels and their associated camera rays in space. Every pixel measures the light traveling along a (half-) ray in 3-space, associated with that pixel. By this definition, calibration simply refers to the computation of the mapping between pixels and the associated 3D rays. Such a mapping can be computed using images of calibration grids, which are objects with known 3D geometry, taken from unknown positions. This general camera model allows to represent non-central cameras; we also consider two special subclasses, namely central and axial cameras. In a central camera, all rays intersect in a single point, whereas the rays are completely arbitrary in a non-central one. Axial cameras are an intermediate case: the camera rays intersect a single line. In this work, we show the theory for calibrating central, axial and non-central models using calibration grids, which can be either three-dimensional or planar.
finalPaper.pdf (1.3 Mo) Télécharger le fichier
hal-01396809 , version 1 (15-11-2016)
Srikumar Ramalingam, Peter Sturm. A Unifying Model for Camera Calibration. IEEE Transactions on Pattern Analysis and Machine Intelligence, 2017, 39 (7), pp.1309-1319. ⟨10.1109/TPAMI.2016.2592904⟩. ⟨hal-01396809⟩
385 Consultations
2062 Téléchargements
