Autonomous parking using a sensor based approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper considers the perpendicular parking problem of car-like vehicles for both forward and reverse maneuvers. A sensor based controller with a weighted control scheme is proposed and is compared with a state of the art path planning approach. The perception problem is threated as well considering a Velodyne VLP-16 as the sensor providing the required exteroceptive information. A methodology to extract the necessary information for both approaches from the sensor data is presented. A fast prototyping environment has been used to develop the parking application, and also used as simulator in order to validate the approach. Preliminary results from simulation and real experimentation show the effectiveness of the proposed approach.
2016_PPNIV_Perez.pdf (2.32 Mo) Télécharger le fichier
hal-01396998 , version 1 (15-11-2016)
  • HAL Id : hal-01396998 , version 1
David Pérez-Morales, Salvador Domínguez-Quijada, Olivier Kermorgant, Philippe Martinet. Autonomous parking using a sensor based approach. 8th Workshop on Planning, Perception and Navigation for Intelligent Vehicles at IEEE Int. Conf. on Intelligent Transportation Systems, IEEE, Nov 2016, Rio de Janeiro, Brazil. ⟨hal-01396998⟩
238 Consultations
729 Téléchargements
