Metamodel-based nested sampling for model selection in eddy-current testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2017
Flaw characterization in eddy current testing usually involves to solve a non-linear inverse problem. Due to high computational cost, sampling algorithms are hardly employed since often requiring to evaluate the forward model many times. However, they have good potential in dealing with complicated forward models. Here, we replace the original forward model by a computationally-cheap surrogate model. Then, we apply a Markov Chain Monte Carlo (MCMC) algorithm to tackle the inversion. The expensive database training part is shifted to off-line calculation. So, we benefit from the MCMC algorithm due to its high estimation accuracy, and do not suffer from the computational burden
Metamodel_based_nested_sampling_for_model_selection_in_eddy_current_testing_PrePrint.pdf (1.84 Mo) Télécharger le fichier
hal-01397025 , version 1 (03-03-2020)
Caifang Cai, Sandor Bilicz, Thomas Rodet, Marc Lambert, Dominique Lesselier. Metamodel-based nested sampling for model selection in eddy-current testing. IEEE Transactions on Magnetics, 2017, 53 (4), pp.6200912. ⟨10.1109/TMAG.2016.2635626⟩. ⟨hal-01397025⟩
350 Consultations
135 Téléchargements
