Attribute-Based Fine-Grained Access Control with User Revocation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wujun Zhang
  • Fonction : Auteur
  • PersonId : 993501
Shu-Lin Wu
  • Fonction : Auteur
  • PersonId : 993502
Yuan-Yuan Gao
  • Fonction : Auteur
  • PersonId : 993503
Jia-Tao Qiu
  • Fonction : Auteur
  • PersonId : 993504
Attribute-based encryption brings a lot of convenience for access control. But it introduces several challenges with regard to the user revocation. In this paper, we propose an access control mechanism using new key update technology to enforce access control policies with efficient user revocation capability. The access control can be achieved by efficient key update technology which takes advantage of the attribute-based encryption and key distribution. We demonstrate how to apply the proposed mechanism to securely manage the cloud data. The analysis results indicate that the proposed scheme is efficient and secure in user revocation.
978-3-642-55032-4_60_Chapter.pdf (343.57 Ko) Télécharger le fichier
hal-01397274 , version 1 (15-11-2016)
Paternité
Jun Ye, Wujun Zhang, Shu-Lin Wu, Yuan-Yuan Gao, Jia-Tao Qiu. Attribute-Based Fine-Grained Access Control with User Revocation. 2nd Information and Communication Technology - EurAsia Conference (ICT-EurAsia), Apr 2014, Bali, Indonesia. pp.586-595, ⟨10.1007/978-3-642-55032-4_60⟩. ⟨hal-01397274⟩
62 Consultations
161 Téléchargements
