An Effective Cloud-Based Active Defense System against Malicious Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Zhenyu Zhang
  • Fonction : Auteur
  • PersonId : 993533
Wujun Zhang
  • Fonction : Auteur
  • PersonId : 993501
Jianfeng Wang
  • Fonction : Auteur
  • PersonId : 993534
Xiaofeng Chen
  • Fonction : Auteur
  • PersonId : 993512
With the rapid development of cloud computing technique, network security has attracted more and more attention. Of all the network threats, malicious code is the major one. Due to the surge of number and species diversity of the malicious code, it is intractable for the existing antivirus techniques to defense all of the attacks. In this paper, we construct an effective cloud-based active defense system against malicious code. The constructed system utilizes the honey-pot subsystem to collect threaten data, and multiple behavior analysis engines work in parallel to generate a comprehensive program behavior analysis report. Furthermore, there are intelligent algorithms running on several computing servers to achieve automatic intelligent analysis on the reports. Associated with the multiple scan engines form a comprehensive, reinforced and more intelligent active defense system.
978-3-642-55032-4_71_Chapter.pdf (415.06 Ko) Télécharger le fichier
hal-01397288 , version 1 (15-11-2016)
Paternité
Zhenyu Zhang, Wujun Zhang, Jianfeng Wang, Xiaofeng Chen. An Effective Cloud-Based Active Defense System against Malicious Codes. 2nd Information and Communication Technology - EurAsia Conference (ICT-EurAsia), Apr 2014, Bali, Indonesia. pp.690-695, ⟨10.1007/978-3-642-55032-4_71⟩. ⟨hal-01397288⟩
145 Consultations
94 Téléchargements
