On Safety of Pseudonym-Based Location Data in the Context of Constraint Satisfation Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tomoya Tanjo
  • Fonction : Auteur
  • PersonId : 993538
Kazuhiro Minami
  • Fonction : Auteur
  • PersonId : 993539
Ken Mano
  • Fonction : Auteur
  • PersonId : 993540
Hiroshi Maruyama
  • Fonction : Auteur
  • PersonId : 993541
Pseudonymization is a promising technique for publishing a trajectory location data set in a privacy-preserving way. However, it is not trivial to determine whether a given data set is safely publishable against an adversary with partial knowledge about users’ movements. We therefore formulate this safety decision problem based on the framework of constraint satisfaction problems (CSPs) and evaluate its performance with a real location data set. We show that our approach with an existing CSP solver outperforms a polynomial-time verification algorithm, which is designed particularly for this safety problem.
978-3-642-55032-4_52_Chapter.pdf (738.52 Ko) Télécharger le fichier
hal-01397343 , version 1 (15-11-2016)
Paternité
Tomoya Tanjo, Kazuhiro Minami, Ken Mano, Hiroshi Maruyama. On Safety of Pseudonym-Based Location Data in the Context of Constraint Satisfation Problems. 2nd Information and Communication Technology - EurAsia Conference (ICT-EurAsia), Apr 2014, Bali, Indonesia. pp.511-520, ⟨10.1007/978-3-642-55032-4_52⟩. ⟨hal-01397343⟩
92 Consultations
41 Téléchargements
