Formal Verification of Complex Properties on PLC Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Formal verification has become a recommended practice in the safety-critical application areas. However, due to the complexity of practical control and safety systems, the state space explosion often prevents the use of formal analysis. In this paper we extend our former verification methodology with effective property preserving reduction techniques. For this purpose we developed general rule-based reductions and a customized version of the Cone of Influence (COI) reduction. Using these methods, the verification of complex requirements formalised with temporal logics (e.g. CTL, LTL) can be orders of magnitude faster. We use the NuSMV model checker on a real-life PLC program from CERN to demonstrate the performance of our reduction techniques.
978-3-662-43613-4_18_Chapter.pdf (541.19 Ko) Télécharger le fichier
hal-01398021 , version 1 (16-11-2016)
Paternité
Dániel Darvas, Borja Fernández Adiego, András Vörös, Tamás Bartha, Enrique Blanco Viñuela, et al.. Formal Verification of Complex Properties on PLC Programs. 34th Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2014, Berlin, Germany. pp.284-299, ⟨10.1007/978-3-662-43613-4_18⟩. ⟨hal-01398021⟩
99 Consultations
225 Téléchargements
