Staffing optimization with chance constraints for emergency call centers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a staffing problem with probabilistic constraints in an emergency call center. The aim is to minimize the total cost of agents while satisfying chance constraints defined over the service level and the average waiting time, in a given set of time periods. We provide a mathematical formulation of the problem in terms of probabilities and expectations. We define a sample average approximation (SAA) version of this problem whose solution converges to that of the exact problem when the sample size increases. We also propose a quick and simple simulation-based (heuristic) algorithm to compute a good (nearly optimal) staffing solution for the SAA problem. We illustrate and validate our algorithm with a simulation model based on real data from the 911 emergency call center of Montreal, Canada.
mosim16emergency.pdf (267.71 Ko) Télécharger le fichier
hal-01399507 , version 1 (19-11-2016)
  • HAL Id : hal-01399507 , version 1
Thuy Anh Ta, Pierre L'Ecuyer, Fabian Bastin. Staffing optimization with chance constraints for emergency call centers. MOSIM 2016 - 11th International Conference on Modeling, Optimization and Simulation , Aug 2016, Montréal, Canada. ⟨hal-01399507⟩
452 Consultations
414 Téléchargements
