Motion anticipation in a Virtual Retina - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mémoires D'étudiants -- Hal-Inria+ Année : 2016
The aim of the internship is to use and update the software VirtualRetina http://www-sop.inria.fr/neuromathcomp/public/Software/virtualretina/, a simulator implementing a retinal model developed initially by Adrien Wohrer and Pierre Kornprobst and integrated by Enas, a software developed by Biovision, in order to reproduce the activity of the retina in response to the stimulus of a moving bar, observed By Mr Berry & al. [1] A form of anticipation of the movement has been demonstrated experimentally by its authors in salamander, rabbit and goldfish retinas. This anticipation can be explained, in the case of a simple trajectory, by the gain control mechanism specific to the ganglion cells, implemented by Virtual-Retina. But for more complex trajectories, lateral connectivity could also play a role.
rapport.pdf (3.69 Mo) Télécharger le fichier
hal-01399940 , version 1 (21-11-2016)
  • HAL Id : hal-01399940 , version 1
Selma Souihel. Motion anticipation in a Virtual Retina. Informatique [cs]. 2016. ⟨hal-01399940⟩
147 Consultations
89 Téléchargements
