Numerical study of thermomagnetic cycle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Magnetism and Magnetic Materials Année : 2016
We estimate the efficiency and power of a thermal energy harvesting thermodynamic cycle using a magnetocaloric material as active substance. The thermodynamic cycle is computed using an equation of state, either extrapolated from experimental data or deduced using a phenomenological Landau model. The magnetic work is then compared to the maximum work. Afterwards power is estimated using a simple thermal exchange model. Simulations of different cycles for different working points illustrate the tradeoff between power and efficiency.
AIM2016_Fullpaper_ALMANZAv8.pdf (1.82 Mo) Télécharger le fichier
hal-01400798 , version 1 (29-11-2016)
Morgan Almanza, Alexandre Pasko, Frédéric Mazaleyrat, Martino Lobue. Numerical study of thermomagnetic cycle. Journal of Magnetism and Magnetic Materials, 2016, ⟨10.1016/j.jmmm.2016.11.058⟩. ⟨hal-01400798⟩
269 Consultations
152 Téléchargements
