Abstract : It has by now become a standard approach to use the theory of sparse (or toric) elimination, based on the Newton polytope of a polynomial, in order to reveal and exploit the structure of algebraic systems. This talk surveys compact formulae, including older and recent results, in sparse elimination. We start with root bounds and juxtapose two recent formulae: a generating function of the m-Bézout bound and a closed-form expression for the mixed volume by means of a matrix permanent. For the sparse resultant, a bevy of results have established determinantal or rational formulae for a large class of systems, starting with Macaulay. The discriminant is closely related to the resultant but admits no compact formula except for very simple cases. We offer a new determinantal formula for the discriminant of a sparse multilinear system arising in computing Nash equilibria. We introduce an alternative notion of compact formula, namely the Newton polytope of the unknown polynomial. It is possible to compute it efficiently for sparse resultants, discriminants, as well as the implicit equation of a parameterized variety. This leads us to consider implicit matrix representations of geometric objects.
https://hal.inria.fr/hal-01401132 Contributor : Ioannis EmirisConnect in order to contact the contributor Submitted on : Friday, October 13, 2017 - 11:19:52 AM Last modification on : Friday, February 4, 2022 - 3:18:36 AM Long-term archiving on: : Sunday, January 14, 2018 - 12:28:03 PM
Ioannis Z. Emiris. Compact Formulae in Sparse Elimination. ISSAC 2016 - International Symposium on Symbolic and Algebraic Computation, Jul 2016, Waterloo, Canada. pp.1 - 8, ⟨10.1145/2930889.2930943⟩. ⟨hal-01401132⟩
