Assigned and Unassigned Distance Geometry: Applications to Biological Molecules and Nanostructures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue 4OR: A Quarterly Journal of Operations Research Année : 2016
Considering geometry based on the concept of distance, the results found by Menger and Blumenthal originated a body of knowledge called distance geometry. This survey covers some recent developments for assigned and unassigned distance geometry and focuses on two main applications: determination of three-dimensional conformations of biological molecules and nanostructures.
hal-01401745 , version 1 (23-11-2016)
Simon J.L. Billinge, Philip M. Duxbury, Douglas S. Gonçalves, Carlile Lavor, Antonio Mucherino. Assigned and Unassigned Distance Geometry: Applications to Biological Molecules and Nanostructures. 4OR: A Quarterly Journal of Operations Research, 2016, 14 (4), pp.337-376. ⟨10.1007/s10288-016-0314-2⟩. ⟨hal-01401745⟩
890 Consultations
0 Téléchargements
