Parametric LTL on Markov Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is concerned with the verification of finite Markov chains against parametrized LTL (pLTL) formulas. In pLTL, the until-modality is equipped with a bound that contains variables; e.g., $\Diamond _{\leqslant x}\ \varphi$ asserts that ϕ holds within x time steps, where x is a variable on natural numbers. The central problem studied in this paper is to determine the set of parameter valuations V ≺ p (ϕ) for which the probability to satisfy pLTL-formula ϕ in a Markov chain meets a given threshold ≺ p, where ≺ is a comparison on reals and p a probability. As for pLTL determining the emptiness of V> 0(ϕ) is undecidable, we consider several logic fragments. We consider parametric reachability properties, a sub-logic of pLTL restricted to next and $\Diamond _{\leqslant x}$, parametric Büchi properties and finally, a maximal subclass of pLTL for which emptiness of V> 0(ϕ) is decidable.
978-3-662-44602-7_17_Chapter.pdf (384.77 Ko) Télécharger le fichier
hal-01402042 , version 1 (24-11-2016)
Paternité
Souymodip Chakraborty, Joost-Pieter Katoen. Parametric LTL on Markov Chains. 8th IFIP International Conference on Theoretical Computer Science (TCS), Sep 2014, Rome, Italy. pp.207-221, ⟨10.1007/978-3-662-44602-7_17⟩. ⟨hal-01402042⟩
73 Consultations
55 Téléchargements
