Generic Partition Refinement Algorithms for Coalgebras and an Instantiation to Weighted Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Coalgebra offers a general framework for modelling different types of state-based systems. Our aim is to present generic algorithms to decide behavioural equivalence for coalgebras which generalize partition refinement. The underlying idea of the algorithms is to work on the final chain and to factor out redundant information. If the algorithm terminates, the result of the construction is a representative of the given coalgebra that is not necessarily unique and that allows to precisely answer questions about behavioural equivalence. We apply the algorithm to weighted automata over semirings in order to obtain a procedure for checking language equivalence for a large number of semirings.
978-3-662-44602-7_24_Chapter.pdf (296.62 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01402080 , version 1 (24-11-2016)
Barbara König, Sebastian Küpper. Generic Partition Refinement Algorithms for Coalgebras and an Instantiation to Weighted Automata. 8th IFIP International Conference on Theoretical Computer Science (TCS), Sep 2014, Rome, Italy. pp.311-325, ⟨10.1007/978-3-662-44602-7_24⟩. ⟨hal-01402080⟩
197 Consultations
136 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
