The Inhabitation Problem for Non-idempotent Intersection Types
The inhabitation problem for intersection types is known to be undecidable. We study the problem in the case of non-idempotent intersection, and we prove decidability through a sound and complete algorithm. We then consider the inhabitation problem for an extended system typing the λ-calculus with pairs, and we prove the decidability in this case too. The extended system is interesting in its own, since it allows to characterize solvable terms in the λ-calculus with pairs.
Informatique [cs]
