The Inhabitation Problem for Non-idempotent Intersection Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The inhabitation problem for intersection types is known to be undecidable. We study the problem in the case of non-idempotent intersection, and we prove decidability through a sound and complete algorithm. We then consider the inhabitation problem for an extended system typing the λ-calculus with pairs, and we prove the decidability in this case too. The extended system is interesting in its own, since it allows to characterize solvable terms in the λ-calculus with pairs.
978-3-662-44602-7_26_Chapter.pdf (347.63 Ko) Télécharger le fichier
hal-01402082 , version 1 (24-11-2016)
Paternité
Antonio Bucciarelli, Delia Kesner, Simona Ronchi Della Rocca. The Inhabitation Problem for Non-idempotent Intersection Types. 8th IFIP International Conference on Theoretical Computer Science (TCS), Sep 2014, Rome, Italy. pp.341-354, ⟨10.1007/978-3-662-44602-7_26⟩. ⟨hal-01402082⟩
101 Consultations
112 Téléchargements
