Generalized Kubo Formulas for the Transport Properties of Incommensurate 2D Atomic Heterostructures
We give an exact formulation for the transport coefficients of incommensu-rate two-dimensional atomic multilayer systems in the tight-binding approximation. This formulation is based upon the C*-algebra framework introduced by Bellissard and collaborators to study aperiodic solids (disordered crystals, quasicrystals, and amorphous materials), notably in the presence of magnetic fields (quantum Hall effect). We also present numerical approximations and test our methods on a one-dimensional incommensurate bilayer system.
MultilayerKubo.pdf (6.21 Mo)
Télécharger le fichier
1D_Toy_Model.pdf (316.29 Ko)
1D_Toy_Model2.pdf (315.14 Ko)
ConductivityScan.pdf (872.59 Ko)
ConductivityVsOccupancy.pdf (925.48 Ko)
Configuration.pdf (88.47 Ko)
Configuration_1.pdf (264.82 Ko)
Configuration_2.pdf (121 Ko)
Configuration_3.pdf (117.57 Ko)
DoSScan.pdf (632.71 Ko)
Layers.pdf (1.98 Mo)
heterostructure-top.pdf (594.52 Ko)
