On Code Coverage of Extended FSM Based Test Suites: An Initial Assessment
In this paper, we present an assessment of the fault coverage of several Extended FSM (EFSM) based test suites. More precisely, EFSM specifications and their corresponding Java implementations are considered. Mutants of these implementations are derived using the standard arithmetic, conditional, and relational mutation operators. The fault coverage of test suites derived by different EFSM based strategies are evaluated and obtained results are summarized.
