On Code Coverage of Extended FSM Based Test Suites: An Initial Assessment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Khaled El-Fakih
  • Fonction : Auteur
  • PersonId : 994816
Tariq Salameh
  • Fonction : Auteur
  • PersonId : 994817
Nina Yevtushenko
  • Fonction : Auteur
  • PersonId : 976864
In this paper, we present an assessment of the fault coverage of several Extended FSM (EFSM) based test suites. More precisely, EFSM specifications and their corresponding Java implementations are considered. Mutants of these implementations are derived using the standard arithmetic, conditional, and relational mutation operators. The fault coverage of test suites derived by different EFSM based strategies are evaluated and obtained results are summarized.
978-3-662-44857-1_16_Chapter.pdf (221.25 Ko) Télécharger le fichier
hal-01405288 , version 1 (29-11-2016)
Paternité
Khaled El-Fakih, Tariq Salameh, Nina Yevtushenko. On Code Coverage of Extended FSM Based Test Suites: An Initial Assessment. 26th IFIP International Conference on Testing Software and Systems (ICTSS), Sep 2014, Madrid, Spain. pp.198-204, ⟨10.1007/978-3-662-44857-1_16⟩. ⟨hal-01405288⟩
90 Consultations
168 Téléchargements
