New interface
Journal articles
Avoiding local minima in the potential field method using input-to-state stability
Abstract : Supported by a novel field definition and recent control theory results, a new method to avoid local minima is proposed. It is formally shown that the system has an attracting equilibrium at the target point, repelling equilibriums in the obstacles centers and saddle points on the borders. Those unstable equilibriums are avoided capitalizing on the established Input-to-State Stability (ISS) property of this multistable system. The proposed modification of the PF method is shown to be effective by simulation for a two variables integrator and then applied to an unicycle-like wheeled mobile robots which is subject to additive input disturbances.
Document type :
Journal articles
Complete list of metadata
Cited literature [44 references]  Display  Hide  Download
https://hal.inria.fr/hal-01405349
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Tuesday, November 29, 2016 - 5:56:31 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Monday, March 27, 2017 - 8:32:04 AM
File
Manuscript.pdf
Identifiers
Collections
Citation
G Guerra, Denis Efimov, Gang Zheng, Wilfrid Perruquetti. Avoiding local minima in the potential field method using input-to-state stability. Control Engineering Practice, 2016, 55, pp.174 - 184. ⟨10.1016/j.conengprac.2016.07.008⟩. ⟨hal-01405349⟩
Share
Metrics
Record views
312
Files downloads
1711
