Journal articles
A Critical Reassessment of Evolutionary Algorithms on the Cryptanalysis of the Simplified Data Encryption Standard Algorithm
Abstract : In this paper we analyze the cryptanalysis of the simplified data encryption standard algorithm using meta-heuristics and in particular genetic algorithms. The classic fitness function when using such an algorithm is to compare n-gram statistics of a the decrypted message with those of the target message. We show that using such a function is irrelevant in case of Genetic Algorithm, simply because there is no correlation between the distance to the real key (the optimum) and the value of the fitness, in other words, there is no hidden gradient. In order to emphasize this assumption we experimentally show that a genetic algorithm perform worse than a random search on the cryptanalysis of the simplified data encryption standard algorithm.
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01406498
Contributor : Fabien Teytaud Connect in order to contact the contributor
Submitted on : Thursday, December 1, 2016 - 11:36:56 AM
Last modification on : Thursday, November 25, 2021 - 8:22:29 AM
Long-term archiving on: : Tuesday, March 21, 2017 - 5:22:48 AM
File
crypto.pdf
Identifiers
Collections
Citation
Fabien Teytaud, Cyril Fonlupt. A Critical Reassessment of Evolutionary Algorithms on the Cryptanalysis of the Simplified Data Encryption Standard Algorithm. International Journal on Cryptography and Information Security, 2014, 4, pp.1 - 11. ⟨10.5121/ijcis.2014.4201⟩. ⟨hal-01406498⟩
Share
Metrics
Record views
54
Files downloads
72
