A semi-Lagrangian algorithm in policy space for hybrid optimal control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
The mathematical framework of hybrid system is a recent and general tool to treat control systems involving control action of heterogeneous nature. In this paper, we construct and test a semi-Lagrangian numerical scheme for solving the Dynamic Programming equation of an infinite horizon optimal control problem for hybrid systems. In order to speed up convergence, we also propose an acceleration technique based on policy iteration. Finally, we validate the approach via some numerical tests in low dimension.
PI_ibridi_v7_arxiv.pdf (2.48 Mo) Télécharger le fichier
hal-01406544 , version 1 (01-12-2016)
hal-01406544 , version 2 (09-12-2016)
  • HAL Id : hal-01406544 , version 2
Roberto Ferretti, Achille Sassi. A semi-Lagrangian algorithm in policy space for hybrid optimal control problems. 2016. ⟨hal-01406544v2⟩
254 Consultations
240 Téléchargements
