On the numerical stability of surface-atmosphere coupling in weather and climate models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geoscientific Model Development Discussions Année : 2016
Coupling the atmosphere with the underlying surface presents numerical stability challenges in cost-effective model integrations used for operational weather prediction or climate simulations. These are due to the choice of large integration time-step compared to the time physical scale of the problem, aiming at reducing computational burden, and to an explicit flux coupling formulation, often preferred for its simplicity and modularity. Atmospheric models therefore use the surface-layer temperatures (representative of the uppermost soil, snow, ice, water, etc.,) at the previous integration time-step in all surface-5 atmosphere heat-flux calculations and prescribe fluxes to be used in the surface models' integrations. Although both models may use implicit formulations for the time stepping, the explicit flux coupling can still lead to instabilities. In this study, idealized simulations with a fully coupled implicit system are performed to derive an empirical relation between surface heat flux and surface temperature at the new time level. Such a relation mimics the fully implicit formulation by allowing to estimate the surface temperature at the new time level without solving the surface heat diffusion problem. It is 10 based on similarity reasoning and applies to any medium with constant heat diffusion and heat capacity parameters. The advantage is that modularity of the code is maintained and that the heat flux can be computed in the atmospheric model in such a way that instabilities in the snow or ice code are avoided. Applicability to snow/ice/soil models with variable density is discussed, and the loss of accuracy turns out to be small. A formal stability analysis confirms that the parametrized implicit flux coupling is unconditionally stable.
beljaars_etal_rev2.pdf (803.35 Ko) Télécharger le fichier
hal-01406623 , version 1 (01-12-2016)
hal-01406623 , version 2 (23-01-2017)
Anton Beljaars, Emanuel Dutra, Gianpaolo Balsamo, Florian Lemarié. On the numerical stability of surface-atmosphere coupling in weather and climate models. Geoscientific Model Development Discussions, 2016, pp.1 - 19. ⟨10.5194/gmd-2016-96⟩. ⟨hal-01406623v1⟩
492 Consultations
343 Téléchargements
