A Coalgebraic View of Characteristic Formulas in Equational Modal Fixed Point Logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The literature on process theory and structural operational semantics abounds with various notions of behavioural equivalence and, more generally, simulation preorders. An important problem in this area from the point of view of logic is to find formulas that characterize states in finite transition systems with respect to these various relations. Recent work by Aceto et al. shows how such characterizing formulas in equational modal fixed point logics can be obtained for a wide variety of behavioural preorders using a single method. In this paper, we apply this basic insight from the work by Aceto et al. to Baltag’s “logics for coalgebraic simulation” to obtain a general result that yields characteristic formulas for a wide range of relations, including strong bisimilarity, simulation, as well as bisimulation and simulation on Markov chains and more. Hence this paper both generalizes the work of Aceto et al. and makes explicit the coalgebraic aspects of their work.
328263_1_En_6_Chapter.pdf (399.44 Ko) Télécharger le fichier
hal-01408754 , version 1 (05-12-2016)
Paternité
Sebastian Enqvist, Joshua Sack. A Coalgebraic View of Characteristic Formulas in Equational Modal Fixed Point Logics. 12th International Workshop on Coalgebraic Methods in Computer Science (CMCS), Apr 2014, Grenoble, France. pp.98-117, ⟨10.1007/978-3-662-44124-4_6⟩. ⟨hal-01408754⟩
186 Consultations
73 Téléchargements
