Effective Surface Normals Based Action Recognition in Depth Images
In this paper, we propose a new local descriptor for action recognition in depth images. The proposed descriptor relies on surface normals in 4D space of depth, time, spatial coordinates and higher-order partial derivatives of depth values along spatial coordinates. In order to classify actions, we follow the traditional Bag-of-words (BoW) approach, and propose two encoding methods termed Multi-Scale Fisher Vector (MSFV) and Temporal Sparse Coding based Fisher Vector Coding (TSCFVC) to form global representations of depth sequences. The high-dimensional action descriptors resulted from the two encoding methods are fed to a linear SVM for efficient action classification. Our proposed methods are evaluated on two public benchmark datasets, MSRAction3D and MSRGesture3D. The experimental result shows the effectiveness of the proposed methods on both the datasets.
Domains
Artificial Intelligence [cs.AI]
