Resource aggregation for task-based Cholesky Factorization on top of modern architectures - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
(1, 2) , (3, 2, 4) , (5) , (1, 2, 4) , (1, 2, 4)
1
2
3
4
5
Hybrid computing platforms are now commonplace, featuring a large number of CPU cores and accelerators. This trend makes balancing computations between these heterogeneous resources performance critical. In this paper we propose ag-gregating several CPU cores in order to execute larger parallel tasks and improve load balancing between CPUs and accelerators. Additionally, we present our approach to exploit internal parallelism within tasks, by combining two runtime system schedulers: a global runtime system to schedule the main task graph and a local one one to cope with internal task parallelism. We demonstrate the relevance of our approach in the context of the dense Cholesky factorization kernel implemented on top of the StarPU task-based runtime system. We present experimental results showing that our solution outperforms state of the art implementations on two architectures: a modern heterogeneous machine and the Intel Xeon Phi Knights Landing.
submission.pdf (345.03 Ko) Télécharger le fichier
Dates and versions
hal-01409965 , version 1 (06-12-2016)
Identifiers
  • HAL Id : hal-01409965 , version 1
Cite
Terry Cojean, Abdou Guermouche, Andra Hugo, Raymond Namyst, Pierre-André Wacrenier. Resource aggregation for task-based Cholesky Factorization on top of modern architectures. 2016. ⟨hal-01409965⟩
453 View
253 Download
Share
