Supervisory Acceleration of Convergence for Homogeneous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2017
The rate of convergence to the origin for a chain of integrators stabilized by homogeneous feedback is accelerated by a supervisory switching of control parameters. The proposed acceleration algorithm ensures a fixed-time convergence for otherwise exponentially or finite-time stable homogeneous closed-loop systems. Bounded disturbances are taken into account. The results are especially useful in the case of exponentially stable systems widespread in the practice. The proposed switching strategy is illustrated by computer simulation.
HomoAccel_J.pdf (393.23 Ko) Télécharger le fichier
hal-01411088 , version 1 (07-12-2016)
Denis Efimov, Arie Levant, Andrey Polyakov, Wilfrid Perruquetti. Supervisory Acceleration of Convergence for Homogeneous Systems. International Journal of Control, 2017, ⟨10.1080/00207179.2016.1269949⟩. ⟨hal-01411088⟩
625 Consultations
219 Téléchargements
